is this normal?
it does it every day on my 27 mile drive to work.
I would think after 3000+ miles since I reset it, the LMPG would be pretty darn stable....right?
Wrong.................The less miles, the more active the LMPG will be.
You are only jumping about .2 mpg per change.
Look at it as "the quicker it will respond"..
I'm assuming you reset the LMPG 3K ago.
I think the better challenge would have been to raise the LMPG from the original LMPG. (You had 47K on the odometer when you got it?)
correct, I bought the car with 47K miles on it and immediately reset the LMPG....now after approx 3000 miles of my driving it, the LMPG fluctuates regularly between 71.2/70.9/71.4...after 3000 miles, should it be still jumping around?
I'll start my commute with it reading 71.2....it'll go to 71.4 then 70.9 :shock: -- then back to 71.4 or 71.2
it just seems like after 3000+ miles it would be relatively stable....maybe that IS relatively stable...??
