1 - 20 of 29 Posts
It's been raining, so it didnt take much to coat the whole section of driveway.
There was some oil pooled on the engine undertray, but thats all I could see. Coolant is full, engine oil still at normal.
Will report what I find tomorrow when I get the car on jack stands. I hope its something minor.
Maybe from a different vehicle?
unfortunately, it was from my insight.
seems to have a slow leak out the bottom half moon section seal of the crank pulley... I tightened the oil pan bolts, they were all loose
bottom bolt of that rear cam tensioner housing thingy was loose a few turns, definitely leaking out of that, lots of evidence
the entire rear valve cover area weeping oil
Unrelated, the rear engine belly pan bolts have worked themselves loose, lost two on the road, the other two were on their last threads ready to drop. Found a compatable bolt in my bag-o-bolts, and I'll go to ACE hardware looking for one new bolt.
I also noticed there are two brass bungs in the bottom intake plenum, both capped, about two inches apart... interesting
So looks like I'll need a reseal of oil pan (iirc this car just uses silicone, correct?) and maybe a half moon seal if it uses them (my ex miata used them in that location) new valve cover gasket, and I'll monitor the rear cam housing.
So I spoke with local NAPA, the oil pan is just the two half moon seals, and import gasket maker. Valve cover gasket isn't showing a schematic, does anyone know if I need o-rings or other parts for a complete valve cover job?
Both parts are 5 days away special order.
Thanks
Have you been adding oil from time to time since you owned the vehicle?
There are 5 gaskets associated with the oil pan and a tube of Hondabond.
There is a front main seal and an
O-ring behind the crankshaft pulley.
While you are there you should consider an accessory belt and an idler pulley bearing.
Scott
Discussion Starter #9
Scott
So there are the two half moon seals, front main seal, and crankshaft pulley O-ring... Whats the 5th gasket/seal?
I have a new belt ready to go in, I'll get an idler pulley bearing too.
Thank you for your help
Nope not at all, but all of a sudden its gushing oil. I'm checking the oil before and after necessary driving, I'll have to start adding tomorrow for sure, it's going down noticeably.
When doing an oil pan re-seal, there are the front and rear lip seals you describe, there is a rubber gasket where the oil pan top edge directs oil to the oil filter mount it looks like a double O-ring in our shop we refer to it as (the figure 8 gasket). Then there are 2 O-rings under the oil filter mount, the mount has 2 water lines attached to it. We do not disconnect the water lines we unscrew the nipple in the middle and leave the mount on the car when pulling the pan. Once the pan is back on the engine replace the 2 O-rings.
Scott
Discussion Starter #11
I checked with all my local autoparts stores for the front main seal, idler pulley bearing, crankshaft pulley o ring, figure 8 gasket, and oil filter mount o-rings, nothing came up in their system except the main seal, and no one in the country had it...
They may not have it, however I stock all of it.
If you would like me to send you a quote via PM/conversation I can do that. Also, I can ship USPS Priority.
Scott
Discussion Starter #13
Oh, I'm finding everything on hondapartsnow and hondapartswholesaledirect, except the idler pulley bearing.
I am doing this repair with just basic hand tools, in a garage. I'm a slow mechanic, but I have 2.5 days coming soon I'll be able to work on the car. Is this an easy job, just time consuming?
Should I make sure I have any specific tool that would make the job easier?
Thanks
How did you find the parts online? Did you search?
Is it as hard job? I find it kind of basic, however I’ve been working on cars for 35+ years.
There might be a special tool or two.
Scott
Discussion Starter #15
Yes, most of the parts I eventually found, but had to call the wholesale website, they gave me the part numbers of the idler pulley collars.
I have two different bearing pullers, little picks, a chisel, hopefully the seals wont give me a problem. I think I'll need a brass wire brush for the drill to get all the gasket material off the pan? or do you recommend a solvent of some kind? razor blade?
Thanks
Discussion Starter #16
Scott
I pm'd you, I won't get the parts fast enough from the websites, let me know please.
Not sure I'd be going to NAPA for Insight parts. Valve cover gasket just one piece Honda #12341-PHM-000 or Victor: 71-53757-00 or Beck Arnley: 036-1601 about $10
Discussion Starter #18
Thanks, I actually ended up cancelling that order, everything is oem including the sealant.
I sent you a conversation regarding your list of parts.
Scott
  • Like
Reactions: Number81
Discussion Starter #20
Im going shopping locally today (thursday) for the rest of what I need for the job.
Should I have some sort of wire wheel or solvent for sealant removal on the oilpan?
Ill need
-new oil
-emery cloth for the crank spacer groove
-something to hold crank pulley while impacting bolt off
-to charge up impact battery
1 - 20 of 29 Posts
