1 - 3 of 3 Posts
1. On a cover at legs of the passenger or driver
Solution: Will paste a piece of foam rubber
2. Over a rear-view mirror
Solution: Wrap up wires the foam polyurethane or foam rubber
3. Knock under the panel about small loudspeakers
The hole of a pipe is groundless and isn't fixed. Honda, what is it!!!:confused:
Solution: Use a wire for a hole of an air pipe to the panel. Use the foam polyurethane for an insert between the panel and a pipe. Use foam rubber between glass and the panel.
1 - 3 of 3 Posts
