I finally replaced my trip buttons! Oh, why did I wait so long? I tested all the bulbs in the cluster, but didn't even think about the bezel. I put the bezel from the parts car in it since it looked a little nicer, but noticed only half of the temp display was lit. So before I take it out to replace I'm curious what other lights I'm missing.
With headlights on I see lit:
FCD
Both window switches
Mode
Fan
When pushed these light up:
Rear Defrost
Defrost
Recirculate
They are not all lit with the single blue bulb, correct? That's the only bulb I see from the back side.
Never on:
Mirror
Heat: Off
Auto
Econ
Temp (I think this one should be lit by white bulb)
Flasher Knob
Oh, and I guess right and left side of temp display. I forget if that is when the lights are on or when the system is on.
Kenny where did you get your replacement trip buttons? By the way I still need to get that rear ledge plastic piece from you. No real hurry on that tho.
Eric, I have some I'll give you when you pick up the other piece.
