@mudder
In my thread (solved power supply issue) I detail what I want to do.
Better rectifier cooling, 450vDC capacitor at least 2000uF, better wiring, and a lithium battery pack.
15volts isnt going to kill the battery anytime soon, it survived 15.2-15.5v in my V8 Mercury for a couple years (previous owner installed it), before I replaced it and fixed the Mercury's voltage regulator.
It is supposed to be a maintenance free battery, but I popped the vent covers off and topped the cells off with distilled water. two were slightly low, the rest were okay. Couple good engine start zaps from a 175amp industrial charger, and the battery was once more passing load tests properly (generally a 75 amp load for 10 seconds, stayed above 11.5 volts)
If the battery was the small 51 group like factory, then I would leave the power supplies set to around 13.6-14.0 volts. Size helps shield the damage from overcharging.
For now, I plan on dialing in each power supply so they are each putting out as close to the same voltage as possible. Whether that be 4.5 to 4.8 volts each.
The overall goal (already removed the under hood battery by looping fusebox wire to charging post, and starter wire to charging post of fusebox) is to save a bit of weight, but still be able to enjoy a small stereo setup.
Going to keep it very basic. 4 speakers, 4channel amp, and simply have more bass-oriented speakers in the rear shelf. Plenty of room for deep speakers, now that the air chamber is gone.
