Answering my own question: I lowered the air pressure on the current tires (3 of 4 RE92, one Dunlop) and was happy with the reduced noise and smoother rise while reaching 65 MPG. The car corners well enough. I'm going to try some inexpensive 155/65R14s.I may be in the market for tires soon. I need help with a tire decision.
I used to have a light car which I replaced the 13" tires with cheap junkyard rims on which I put modest Yokohama 185/60r14 tires. (I also did a modest shock and sway bar upgrade).
That car drove and cornered like a dream. So I'm thinking of taking the hit on mileage on this Insight and going for driveability, starting with the tires first. (And maybe the power steering disconnect before attempting anything else since this car already has better suspension).
The Yokohamas may not be available anymore but I was thinking of going with budget Douglas tires anyhow. Will I enjoy such a big ride change over the RE92s that I won't notice an additional difference if I went with more a expensive brand of 185/80r14s? (in which case if I were going to spend the money, I would just get another set of RE92s.)
Thoughts on budget 185/60r14s?
How many miles on the drive cycles. Short trip or long trips. Sounds like you are soon to have a P-1447 CEL on the IMA system.
How many miles on the engine? Need more information.
I was gonna say do the opposite - increase the pressure. I have some suspension mods that allow me to push the car hard in corners, and I find that RE92s can handle an awful lot - if they have about 38 psi or more. Otherwise, they'll fold... I can hit 90 degree corners doing about 35-40 mph, dry, without the tires breaking loose. That seems pretty fast and hard to me... Before the suspension mods, something else would make that feel too scary - so in a stock car it doesn't seem like the tires are the weakest link...Answering my own question: I lowered the air pressure on the current tires (3 of 4 RE92, one Dunlop) and was happy with the reduced noise and smoother rise while reaching 65 MPG. The car corners well enough. I'm going to try some inexpensive 155/65R14s.
In any event, though, sounds like you're after something else, such as comfort ('reduced noise, smoother ride')...
17146-PHM-004Anyone have a source for a cheap intake manifold gasket? The multi-layer one. I don't want to buy a kit for a gasket, I just want to clean out my EGR passages. I also don't want to reuse one if it's under $20.
Update,290,000KM on the motor
1 hour commute to work. 115KMs one way.
With that many codes I would say a ground or a bad 12v battery are prime suspects. I can't remember even seeing once of someone having a bad knock sensor and TPS sensor issues are pretty rare.Update,
Had the following codes come up
P0325 - Knock Sensor
P0420 - Cat below threshold
P1457 - Evap Leak
P1121 - TPS Input Low
P1259 - VTEC Solenoid
Cleared the codes and drove home, only P0325 came back after an hour of highway driving.
will do the following, thanks!With that many codes I would say a ground or a bad 12v battery are prime suspects. I can't remember even seeing once of someone having a bad knock sensor and TPS sensor issues are pretty rare.
When you have low 12v voltage or have an inconsistent ground you get some really strange issues and codes. Mine likes going through the terminal connectors for some reason. Make sure your terminals are clean and then put the special grease on them and tighten them. If you have a multimeter remove and check the grounds have consistent low resistance or just replace them, they're not expensive. Get new hardware and also take the paint off where the ground goes so it's not just trying to put the ground through the threads which are likely corroded by now.
To answer your third question, it's just the 3 orange wires to the 3 leads on the 3-phase rectifier in any order, then two leads from the two on the rectifier to the input on the meanwell, and then connect 12V output from your car to the output leads of the meanwell. There's a little adjustable screw on the back of the meanwell to adjust output voltage.Questions:
1. What would it take to tell the DC-DC converter to turn back on at, say, 12.4 volts instead of when it feels like it?
2. Anyone dealt with P0443? Has to do with the evap valve/circuit, and I think it is only thrown by an 06 (maybe an 05).
3. Gonna put my IMA battery on the bench to charge. Got my 40+ amp Meanwell to charge the 12V on the road while the IMA is out. Don't care about codes being thrown, autostop, etc (this is temporary). Do I just need to connect the Meanwell output to where the DC-DC output connects, and make a full wave rectifier from the IMA motor wires to the Meanwell input? Or is other magic required to make the car start/run?
