I've only had my 06 insight for 2 weeks now, but i've got 1100 miles so far, averaging about 73.0 mpg (thanks to the advice from this forum).
Since there seems to be a conflicing information as far as what's the most FE way to accelerate (NO IMA, vs WOT), I decided to run the following experiment:
Theres a 1.8 mile stretch that is mostly flat near my house. The test run is as follows:
- Reset the segment FCD
- Acellerate to 50mph with varying techniques (depending on data run)
- Hold 50mph using my best lean-burn hold technique
- after 1.8 miles, use max regenerative braking in 5th until it cuts off
- downshift to 2nd, use max regenerative bracking till it cuts off
- quickly make a u-turn, stop, and reapeat back to the starting location. (3.8 miles total)
- record segment FE data, make u-turn, and repeat test.
For some of my runs, I did this with a FULL SoC. (Used regenerative braking untill it refused to charge). Runs labeled NOT Full SoC were done by doing 2 WOT accelerations to 60 to deplete the battery a bit (trying to simulate "real world" vs. "ideal" conditions. Here are the experiments (and results):
Run 1: Using very little acceleration, pretty much the "No IMA" approach. As soon as I hit any assist, I would immediatly back off. I upshifted when the up shift light came on. This was done with a FULL SoC. Result: 75.4mpg over 3.8 miles.
Run 2: Using light acceleration (4-6 bars of Assist). Shifting at around 3k RPM. This was also done with a FULL SoC. Result: 71.6mpg.
Run 3: Using WOT acceleration. Shifting at 4k rpm. Also with FULL SoC. Result: 75.6mpg.
Run 4: Using "No IMA" acceleration. Same shift points as Run1, with 2-bars off a full SoC. Result: 69.0mpg
Run 5: Using WOT acceleration. Sifting at 4k rpm, running 2-bars off a full SoC. Result: 74.4 mpg.
This data seems to imply that WOT acceleration is the best way to go. This makes sense to me, given the P&G discussions I have been reading. I kind of wonder if the WOT approach would be more effective if the shiftpoint was even higher, around 5.5k-6k rpm.
One point to note, however, run 1 was noticably easier to hold lean-burn. I'm assuming this is because background charging wasn't in effect.
I'm now starting to suspect that the #1 factor in maximizing FE is getting into lean-burn as quickly as possible, and holding it for as long as possible, period. All other factors are at least second or third order factors. Also, transitioning from WOT to lean-burn efficiently is *tricky*. It is VERY easy to accelerate to 50mph, and by the time you manage to coax the motor to enter lean-burn, you are down to 40-45mph. If this happens, you are screwed FE-wise.
My technique for transitioning from WOT to lean burn is as follows, feather the throttle slowly easing up until you eventually enter lean-burn. If this takes an extra 5-10 seconds at higher fuel consumption, fine, but the key is to maintain your momentum until you enter lean-burn, because accelerating in lean-burn is very difficult without a downhill slope and/or tailwind to help you.
In any case, I don't know how much of this is "common knowledge", but I found that this data is a bit contradictory to the knowedge base (which encourages WOT acceleration at 2.5-3k rpm shifts) and contradicts the no IMA approach, which only seems viable with a Full SoC, and even then, results in frustrating acceleration.
I've found that WOT acceleration at lower shift points causes you to spend too much time out of lean-burn, sacrificing FE (for tha same reasons that P&G is effective).
I plan on repeating this experiment in the near future with the WOT approach and verying my shift points. I post results here when I do. I hope you guys found this as interesting as I did.
