Hi all,
I see this get asked a lot in other posts so I've compiled all of the info I could find on the Stock wheels and tires.
Stock Wheel
Mfg: Asahi Tec Corporation
Size: 14 x 5.5 J
Bolt Pattern: 4-100mm
Lug Size: 12 x 1.5mm
Offset: +45H
Weight: 11 lbs
Finish: Aluminum
Style: 12 slot
Stock Tire
Mfg: Bridgestone
Model: Potenza RE92
Compound: 78S
Treadwear: 260
Traction: A
Temp: B
Weight: 11.5
Pressure: 44psi
RPM: 926
The following tire sizes are currently available to fit the stock wheel from major tire chains.
165/65 R14
175/65 R14 -2.3 MPH difference at speedo, 908 RPM
185/60 R14 -1.3 MPH difference at speedo, 914 RPM
195/55 R14 0.0 (same as stock)
Note:
The Maximum fitment tire and wheel size for the Insight is the 205/40 R16x7 while retaining the same tire diameter. And yes, this size fits quite easily behind the wheel skirts.
Stock Wheel
Size: 14 x 5.5 J
Offset: +45H
Weight: 11 lbs
Finish: Aluminum
Style: 12 slot
Stock Tire
Mfg: Bridgestone
Model: Potenza RE92
Compound: 78S
Treadwear: 260
Traction: A
Temp: B
Weight: 11.5
Pressure: 44psi
RPM: 926
165/65 R14
Note:
