Hi folks , 2011 insight owner from Ireland.
Washed my car today and noticed peeling inside the back wheel wells looks like the coating is peeling exposing the paint work.
Ive attched some pics.
Just wondering should i be concerned that this black coating is peeling away? Would lead to rusting? Any advice would be greatly appreciated. Thanks 20190803_181618.jpg 20190803_181615.jpg
If they salt the roads there, then it might be a matter of some concern. Here in the U.S. you can buy undercoating in aerosol cans - so you could repair the peel. Just trim away the loose parts and spray.
Thanks for the reply.
Yeah they do salt the roads here alot.
I'll just spray the exposed paint areas then after cutting away loose bits. Would the spray do any harm to brakes etc if it were to land on them? Thanks
As I recall, the Gen2 has drums on the rear so no problem there. Just put an old newspaper over the front disc brakes and you should be fine:)
Can you recommend an undercoating i could use? that would be similar to the factory sealer? thanks for all your help much appreciated.
