1 - 13 of 13 Posts
Having a 2010 Insight, i just learned that the original insight was more economical???
Why is the original one more economic and any idea if Honda will bring back electric or hybrid to North America anytime soon?
The original Insight was designed for maximum efficiency and likely sold for less than it cost to build. Fewer than 20,000 were sold worldwide, so it probably didn't cost Honda very much to get real-world experience with its first hybrid.
It is extremely light at ~1,900 lb. This is due to an expensive aluminum unibody with aluminum and thermoplastic exterior panels and its very small 2-passenger size. Aluminum was used extensively throughout (e.g., aluminum front suspension arms, aluminum rear brake drums, aluminum front brake calipers).
It is very aerodynamic with a Cd of only 0.25. This is possible in part because of a very smooth underside and rear fender skirts.
The small, very light, 1 liter, 3-cylinder engine has an offset crankshaft to reduce piston friction. It has roller bearing cam followers to reduce friction. Manual transmission versions have an engine that can run at very lean air:fuel ratios (24:1 compared with the usual 15:1). The engine has a very high compression ratio for more efficient combustion.
It was sold with very low rolling resistance tires.
So Honda engineers used almost every trick in the book to design the most fuel-efficient car ever sold in the U.S. This would have been too expensive for a larger mass-market car like the second generation Insight.
Unfortunately, Honda doesn't seem to have much interest in producing a battery EV. Instead, hydrogen fuel cell EV's seem to be Honda's and Japan's primary focus. No Japanese car manufacture sells a battery EV at this time.
Edit: Ignore the final sentence which is false - Nissan Leaf, of course, and our first EV, a Mitsubishi i-MiEV! Doh!
thanks aisble for the awesome info.
Wow, had no idea there was such a difference between the 1st and 2nd generation insights.
Hope Honda will bring their Hydrogen Clarity model to market soon.
Just to add, Nissan do sell a battery EV - the Leaf. Is it not available in the USA?
Of course! How embarrassing! The Leaf was a pioneer EV in the U.S. and, of course, is still being sold here. My brother owns one and I rejected the Leaf when we purchased our first EV, a Mitsubishi i-MiEV, also a Japanese EV and still sold in the U.S. Senior brain freeze :)
The large Japanese car manufacturers, Honda and Toyota, don't seem interested in selling a battery EV. Fuel cell EV's like the Honda Clarity and Toyota Mirai are much less energy efficient than a battery EV. Refueling them is possible only in a few locations. Hydrogen and the hydrogen generators are very expensive. Almost all hydrogen is made by reforming natural gas which releases CO2, so hydrogen made this way doesn't help with climate change. About the only advantage of a fuel cell EV over a battery EV that I can think of is faster refueling, but battery EV charging speed is increasing, so this advantage may become less important.
hope we will get such cars in Canada soon.
Not too many electric cars on the road here in Montreal, although government does subsidize about $8000 CAN off cost of car. Probably the lower Canadian dollar value compared to 2 years ago affected the buying power..
I drove the Leaf when it first came out but did not like it.
Also looking forward to more news and info on the upcoming Tesla 3.
i would think that more northern latitudes also take a hit in efficiency, longevity, range due to the lower temps and the effect on the battery pack, use of heater, etc.
Discussion Starter #10
yeah. in winter here, specially Jan and Feb when temp is coldest around -20 to -40 celsius, the insight does not do that good of mileage and takes at least a good 4 to 5 mins of warmup to run properly. And with the heater on all the time in car, the car does not cut off gas during stops at lights or in traffic.
(1) Clarity has been on market since 2006 for lessees. (2) You don't want a hydrogen car. I had one for 1.5 years and it has serious flaws: Limited range of 200 or 300 miles. :The refueling process take upto 20 minutes.
Insight G1 versus G2:
- The main difference is the 3-cylinder engine. Both are aerodynamic, but the G1 has the smaller engine. I testdrove a Ford Fiesta with a 3-cylinder engine, and it got amazing fuel economy (70mpg), even though the car is neither aerodynamic or lightweight.
Nothing to do with 838 KG kerb weight on the G1 vs 1240 KG on the G2 then? Little sliver of aliminium vs medium sized lump of steel?
The cars are nothing like each other really.
I moved a bed in my G2.
A medium sized tree that couldn't fly but tried anyway, cut in pieces.
A cubic meter of holiday luggage plus my family of 4 (with the aid of a rooftop box).
Three low but deep drawer cabinets at once.
One high drawer cabinet.
And so on.
None of that would have fitted in a G1.
Take the G1, make it seat 4 plus a sizeable boot and see what you end up with.
But hey, it is not a contest.
These are different cars from different eras that bear the same name and some comparable features.
I'd love to own both generations but for practicalities and the G1 never sold here.
1 - 13 of 13 Posts
About this Discussion
8 Participants
RedDevil
Honda Insight Forum
Full Forum Listing
