1 - 14 of 14 Posts
I've been wanting to change my air filter since buying my car a little over 3 months ago. I don't even know what its condition is since I can't open the air box without removing some other things. I might be better off having a new filter to put in if I'm going to go through all that trouble just to check.
What air filter to use? Can't go wrong with Honda Genuine, but I was wondering if any of the Ebay filters are any good for a lesser price.
Changing the air filter seems pretty straight forward. Other than unlatching the 4 clips, what other things do I need to detach before I can open the air box? Looks like 2 "hoses" on the left side of the box need to be detached before the lid can lift off.
The answer to the original question is pretty obvious.
The remove or inspect your air cleaner nothing needs to be removed, no tools needed as it is only the few snaps unless your car has been modified.
As to what air cleaner - some go with K&N (some think is sounds better, some like the fact that they think it adds some performance, this will be at the cost of it not cleaning s well). I personally stick with stock.
When you do replace it take a damp rag and wipe out the air filter box and hoses as best you can, you'll find lots of dirt and grit in there that you could stop from heading to the engine.
Again, as a rule - I ALWAYS replace all fluids, oil filter, air filter, and plugs when I buy a used car to make sure things are right... even if it was just serviced by a dealer... cheap insurance!
Generally a new air filter will improve performance under high engine speed operation but since late model cars operate by measuring the air flow or manifold pressure, you don't lose much MPG until things get really bad. Having a clogged filter would mean that you rag on it a bit more to get what you want from it when you really want to get moving.
When I bought my car it had a K&N installed, I promptly bought a paper filter and have the K&N sitting in the box that I bought a paper filter in. I generally don't like the picky cleaning and oiling regimen of oiled gauze filters, and if you don't get it oiled perfectly you've got dirt ingestion. I don't have a cleaning kit for mine so the choice was easy for me to go back to a standard paper filter.
The air filter could really help...
My daughter had trouble starting her Toyota Echo about one month ago.
The car would crank very strongly, but simply not fire. My wife noticed a slight smell of fuel. I did get the car to start, but only after holding the throttle wide open until the engine fired.
After much head scratching my wife mentioned changing the plugs and air filter to see what would happen.
Well, she was absolutely correct, as the stock filter was badly plugged, looking quite dark on the air inlet side.
After changing out the components, the car started immediately, just like normal.
Jim.
Leeper, that's the thing. I'm not sure! I've read differing opinions where some people say they didn't notice any change in mpg while others say there was an improvement.
I'm sure there must be some improvement, but is it noticeable? Will I see it and feel more power?
I agree, the filter should have been changed asap, considering that I don't know what its condition is or when it was last changed. Might as well change the air cabin filter too. Though the PO did say that was changed "recently."
When I said "the answer is obvious" I meant that if it is totally clogged then yes, if it is new then no, if it various in between then so might your mileage. The question would be the same as "can a bad spark plug cause problems"? If the air cleaner is in really bad shape it creates bad results. For $15.88 (Majestic Honda) why wait?
You are still trying to put value in the words from a guy that also failed to tell you about the head gasket replacement. Just do your own tune up including the air cleaner and therefore not worry going forward. Those are little things, at little costs, that could make a big difference. Why try to save a couple bucks on these things and not know?
A quick story - when I was young and bought my fist new car - a Civic Si. I drove it for a bit then brought it in for its first scheduled tune up. No doubt that spending that kind of money would certainly make the car feel better somehow. I told a roommate that I brought it in and he asked "does it feel any different?", thought about it and said "no" and felt bummed that it didn't and I spent that money. In hindsight much of this is like changing the oil, it is preventative and hard to quantify but if you don't it could lead to major catastrophes later.
Change your plugs to the right ones per your cylinder head, change your air filter, oil filter, oil, brake fluid, clean your EGR plate, maybe have your coolant changed, and have your valves adjusted. It doesn't matter what the previous owner claims or what receipts he shows just do it. All that is cheap insurance. I cannot tell you how many vehicles I've seen where dealers have done work only to see how badly it was done. There many claims on this board alone where dealers or garages put in the wrong oil or oil levels to the detriment of the car... why take that chance? All of that can easily be done in an afternoon with minimal tools or experience for under $100. Also, I trickle charge the 12v battery at least twice a year.
Yeah, you're right, Leeper, I'm gonna go with installing a new air and cabin filter for safe measure. I think I've been getting good consistent city mpg (53 mpg per 9.9 gallons fill-up--I guess could be better if there weren't so many red lights and stops!). Still, I'm just curious to see the condition of the air filter.
I had the plugs changed to Honda Genuine B plugs (what was stamped on the head) shortly after purchase and the old ones that came out were pretty clean and solid--still have them for my reference). Also had an oil change with HG 0W-20 but with a cheap no-name filter.
Discussion Starter #10
Just stopped by the dealership and got a Honda air filter. It was around $25-something after tax--relatively expensive, but I knew that as I had called other dealers near by and the cheapest was $22-something but not in stock, which would mean I'd have to go to that dealer and place an order (no phone orders) and then go back again once it's in. Majestic has it for $15 but after shipping charges, it'll cost more than the dealer!
I was surprised that the filter looks so much like some of the ones I see on Ebay. Same green color but not the Toki-something brand that is stamped on the Honda filter. Always the frugal person, would I have been better off getting an Ebay filter and saving around $10? I would think they are made of the same materials.
Speaking of changing air filter, it really looks like I just can't unclip the 4 latches. Looks like I'll have to remove the two hoses or something. Arrrrghhhh.
if you are just swapping the filter, its a 30 second job, no hoses etc. But if you want to completely remove the top half of the air-box, then i guess you can remove the hoses. Only reason you would want to do that is if your air-box was dusty/dirty and you wanted to clean it out, otherwise you shouldn't have to open it up all the way
Here is a quick 30sec video i made:
YouTube - airfilter.wmv
Discussion Starter #13
Thanks, 02Insight for the video. I can't watch it on my computer because of some Flash upgrade thing and the fact that my connection has been slow. Will watch it on a work computer. Was it you who posted the "engine sound" video too? That was very helpful. I wish there were more G1 Insight videos on the web--not the commercial types.
Earlier today I did get a chance to look at the air filter. I unclipped the 4 latches and was able to pry the right side of the air box lid 2" to see the filter inside. To my amazement it looked pretty clean. It may well have been changed not too long ago. It wasn't the green Honda Genuine filter. It was a pinkish purple, but I doubt it was a K&N filter as it didn't look oily.
I decided not to change the filter. I'm still eager to check out the video because had the filter needed to be changed, I don't see how I could get it out and slip a new one in with the small gap I opened on one side.
Well the video doesn't show more than what you have already done, but yeah that was me who posted the other video as well. When I have time, I don't mind going outside and taking a quick video and uploading it. It doesnt take more than 10-15 minutes to make and upload a video to youtube. :)
1 - 14 of 14 Posts
About this Discussion
7 Participants
02insight
Honda Insight Forum
Full Forum Listing
