I know a lot of people come to this place to seek free help with car problems and complain when it doesn't come. I will paypal you whatever you think is fair if you can help me diagnose and fix whatever it is I've done wrong to this machine. Not a joke. Now that I've got your attention:
I own a 2003 Insight, it's my 2nd as my first was rear-ended and totaled. I've only had the new one about 3 months, and got the dreaded p1449. I would have considered myself a fairly capable DIY-er before today, so I dove right in to reconditioning the sticks and replacing bad ones. I removed the IMA battery, cycled the sticks, and replaced two that were corroded and not holding a charge. All the rest successfully completed charge and discharge cycles with a Hitek X1 Pro hobby charger. All achieved at or around 74-7500 mAh when the process was complete. Pack was delivering 177V when reassembled.
Upon re-installing the battery, I got a more or less instant check engine light and IMA light. The battery charges itself for a few minutes, then declares itself full before the IMA light comes on a minute or two later and the meter empties itself. Furthermore, the HVAC is no longer responsive to its buttons and the blower begins blowing at random speeds as long as the car is switched on. The OBD returns a p1542; IMA blink code is 59, indicating a high voltage short. No amount of resetting and error code clearing will fix it.
In an attempt to troubleshoot it, I switched the battery breaker off and disconnected the positive and negative leads. Upon doing this, the negative lead underwent what I could only describe as an explosive discharge upon touching the metal on the converter unit, leaving a small scorch mark (I was wearing proper PPE including insulated gloves and I was not hurt, but definitely would have been were I not taking the proper safety precautions. I removed and disassembled the battery again, and reassembled the entire battery array including the bolts and PTC connectors by hand. The result is yet again the same after re-installing the battery.
I'm at my wits' end here, I can't figure out what on earth I've screwed up to make this happen, but it was definitely something I must have reconnected wrong. In an attempt to troubleshoot, I found that removing the connector pictured below stops the blower short from happening, but the IMA doesn't function with this disconnected; I'm not an expert on this thing so I'm not going to pretend like I know what this connector does or why any of this is happening. Upon resetting the IPU by disconnecting and reconnecting the 12V battery, the IMA will assist the engine in accelerating before the light comes on, which leads my uneducated self to think that something wrong is happening when the converter attempts to charge the IMA battery. There has to be something I can do to troubleshoot and fix this.
Insight Central, can you help me?
