1 - 3 of 3 Posts
hello everyone,
first excuse my broken English :D, i have insight 2012 and my front passenger side window regulator is broken so i found a cheap 2009 insight window regulator on eBay.
so my question is would insight 2009 window regulator fit on 2012 version?
thank you
Hello and welcome.
No problem at all but you've posted in the first generation 2000-2006 group vs the second generation 2010-2014 group.
Edit: Moved.
The 2009 listing may not be an issue, but get the correct part number from an online search for your car's trim level, or any marking on the broken one you have, and message the ebay seller to confirm. Check out his 'seller rating' for confidence in the sale. Use your car's serial number on some online parts sites to refine your search. Good luck!
Moderator
1 - 3 of 3 Posts
