1 - 9 of 9 Posts
I know there has been discussion regarding replacement of the window switch, but I cannot find it. Any assistance would be appreciated.
If you just type "window switch" in the search line above, you will get many pages of threads. The main thing is to properly remove the dash bezel. Search on U-tube for "Insight dash bezel removal" to find klr3cyl excellent video on the subject.
It's working now- thanks to the folks that take the time to document solutions.
Yeah, they get intermittent before they fail completely. You'll need klr3cyl video sooner or later. Don't try the dash bezel without it. ;)
Have a few in the garage if you need one.
Thank you Hybrid. Is it the plastic toggle that operates the actual switch? I think in my case it is the toggle because I can operate the slide switch and the window operates just fine.
Do you happen to have a bezel as well?
Your suppose to just toggle it once once it should go down.The button stops functioning and eventually fails,do you mean the whole dash bezel, yes why did you crack yours..most dont take their time and crack it from sun damage or just not knowing its brittleness
1 - 9 of 9 Posts
