Hi, 2000 Insight, tried to start, green key light was blinking indicating computer would not recognize key. Got locksmith to reset computer, worked for about 2 months and now it's doing it again. Any help or suggestions would be appreciated. Thanks, Paul
Does it do it consistently or is the problem intermittent?
Do you have more than one key?
Does it do it with both?
Did one a few months ago and it was the immobilizer antenna ring on the ignition key cylinder had failed. Replaced it with one from a parts car and it solved the problem.
Scott
Thanks, it has done it twice now. Only have the one chipped key. Is there any post or procedure you could reference to remove the immobilizer chip or bypass it?
Thanks
Paul
