a few times in the past I went to start my car and it wouldn't start it acts like I hit the key too fast. waited a couple of moments and then the car would start on the big battery pack as normal.the now it refuses to start, crossed the 12 Volt starter, turns the motor over but didn't fire. No codes, good pack, 13.2 volts on 12 volt battery, good grond straps and shes a cvt 2002! Is there a starter relay or fuel relay bad? Thanks Jim
Discussion Starter #2
Got her started.....wiggled ecm connections, started right up! Its the one under the passengers floor board. Cleaned contact pins and covered them with dielectric grease , although I saw no corrosion.
Looks like he might have sold the Insight in May 2016.
It was a white one.
2000 Honda Insight 5 Speed
Whoops, I'm still learning this site. I'm still glad he was kind enough to post his solution even if he probably isn't active anymore.
