1 - 20 of 42 Posts
I haven't been driving much over the last couple months. I filled-up the other day and registered my worst tank MPG ever - 49.3 per FCD, 48.4 per fill-up calculation... Kind of curious what others' worst tank MPGs look like?.
What's funny is, even 49 mpg is way better than what I used to get in my Miata, for example. I used to be happy when I could eek-out just a bit over 30 mpg on highway trips in that car.
What's interesting is this low tank mpg reflects a few key things:
1) very short trips, like a couple miles, from cold start
2) cold weather (like in the 30s F)
3) low tire pressure
This last one was a real shocker. I kind of thought one of my rear tires looked a bit low, but never got around to checking it. I checked it the other day and it had only 15 psi. The thing is, I actually drove about 120 highway miles on that low tire and still got about 65 mpg... Thought I'd post this, too, as just a heads-up: it's not that easy to tell that the tire pressure is low if it happens from a slow leak, and by just the occasional casual visual inspection. On the other hand, after airing the tire up (and the others, they were a bit low), it's a very noticeable difference...
So, low tank MPG? What's yours?
Probably when I very first got the car, I think I was getting 45-48 for a few tanks, before I learned how to drive it.
It's funny to me that my expectations of MPG have gone way up - if I get below 50mpg on a trip nowadays, I think "yeesh, that's terrible." But it's still better than most all other cars, 50mpg is actually quite a lot!
If I get below 40mpg I know something's wrong with the car. That's how good the Insight is. :)
I've never gotten below 40 MPG (2002 CVT with over 200,000 miles,) but I can remember a time when I had never gotten below 50 MPG! Of course the first few years were the best, hovering around 60 MPG's, but that was when I drove in the sweet MPH range all the time (45-55 MPH.) Lately, the 45-50 MPG mark seems to elude me.:confused:
Engine-Off-Coast
40.08 MPG over a tank of gas as measured by pump/odometer.
It was 100% highway miles, freezing temperature, trying to go fast, loaded down with about 200lbs of stuff, and I had a damaged aero panel on the bottom of the car for half the tank. (I stopped and fixed it about 330 km into the tank, but I suspect it was damaged before I was on this tank.)
My best for comparison was 78.34 mpg.
Also, 40.08 still blows my old car out of the water.
Yeah, that's part of the feeling that compelled me to start a thread: my worst tank mpg, under truly awful conditions, is still better than like 99% of the cars on the road, probably under the best conditions...
For comparison, I've averaged about 65 mpg since I got the car about 5 years ago...
61.77 mpg is my lowest on Y2K (Silver).
88.1 is my best tank.
I have a new-to-me Red Insight, but I'm still working on some issues. Brakes are dragging, tires are wrong size, bumper sensor is missing. Once I get these taken care of I'll start logging MPGs on fuelly. Currently it has been running mid to upper 50's per tank.
I don't think I have gotten under 50 in over 2 years now. October 2014 I fueled up for 48mpg. Since then, my worst tank was 52, and I idled for 6 hours at work that tank per my notes.
gotten close but never below 50mpg, even with the air conditioner on, doing a lot of city driving with a failing IMA and no autostop.
58.5 mpg for a tank, on a road trip with constant wind. Tumbleweeds were airborne across 4 lanes plus the median, and it was a fight to keep the car in one lane with frequent gusts of about 50 mph/43 knots. After tiring of fighting the wind for several hours, I pulled off the road next to a gas station for a nap and the wind rocked the car the rest of the night.
That 48 tank was probably when I filled your tank, you were going like 90 to Scott's place. I had the death grip on anything I could get a hold of. lol
I don't think I have ever gone below 62 with a bad battery.
~40mpg over 500 miles mixed 3/8hwy 5/8ths city.
______________________
TRIP FCD: 5.8L/100km ~41mpg over 800km ~500miles.
HWY" ~300km hwy ~180miles; CITY: ~500 city,~320miles
Continental Sub Arctic Winter cold conditions; short trips mostly <5miles ; stock tires, [some unavoidable wheelspin/->wear]; A/C ON Full, 32C [top] setting to dry windshield air; 'ELD' ~48-58 varies: headlights etc, blower motors, IMA fan on 'F', heated seats,; BCM warming pack 'Bat'; dense air to move through; low IAT; typically slow traffic; idling to keep cabin warm for passenger.
Above # in spite of warm air intake, full radiator block, stock tires, nb. slippage.
Autostop is functional only after about a half hour driving when 'Ect' temp is over about 68C iirc.
LOL. I remember that now.
I think the worst tank I've ever had was around 48mpg. Lately I've only been hitting 50ish per tank, but it's nearly all 70mph highway, with a passenger, and new heavy snow tires.
Banned
This is one competition I am sure I could win if I wanted to.
60 per cent bigger injectors than stock, able to run whatever air/fuel ratios I want, turbo at up to 15 psi.
That said, I've never got a tank worse than about 5.5 litres/100km (43 US mpg).
My worst manually calculated tank full yielded 56.72 MPG average.
I always run 87 octane (and when going cross country have to settle for 85). My driving is roughly 75% highway vs. 25% city.
On the flip side, the best calculated tank full yielded 77.7 MPG and that was nearly pure highway driving at ~55 mph over a single day in very nice weather during a road trip.
The car is all stock with RE92s, at the time pumped at ~40psi
I have since upped the pressure to ~50psi and I am seeing a slight reduction in fuel consumption over the same cold winter months as last year. It has historically dipped significantly during winter months, which is normal.
Worst MPG was about 47 or so. But I only get that when I do a "drive it like when you stole it" on the Autobahn at 85-90 mph in 4th gear. My car seems to like that, LB seems to work better after that cure. I am doing that once a month or so.
1 - 20 of 42 Posts
About this Discussion
27 Participants
YogiMac
Honda Insight Forum
Full Forum Listing
