1 - 16 of 16 Posts
i need to do that and i was wanting to checkout the injectors to. but that still won't get me anywhere near the mileage that the ECU would.
Anyone know why they didn't have that on the US CVT's?
Well, either way you look at it, you’ll get 10 mpg more. I’m now getting between 55 and 63 mpg on highway keeping it around 60mph. I haven’t gotten under 52mpg.
yeah that would be better but i'd still like to get JDM ECU and be at 70-80.
You'll need more than just the ECU.
Read.
this getting 40-45mpg in a CVT is painful.
You have other issues, CVT should be getting mid 50's mpg without trying. What tires are you running? What speed do you cruise at? It takes some practice to get max mpgs.
Indeed. I'm at just over 105K on my 2001, lifetime mpg 55.4, with the AC set on 72/econ that has never been turned off ever since day one 18+ yesrs ago... And it would have been higher, probably, had My Beloved not driven it like a Civic before I gained greater custody of the car after a few years.
Right. Don't set your expectations too high. Mine doesn't get anywhere near the numbers you're talking about. As long as the car is right the problem is the driver, the environment, or the commute.
As far as your other question, Honda did it on purpose so they could advertise the SULEV EPA rating.
I’m curious what MPG gain you did get from the lean burn. I’m considering tracking down a module but they are $800 or more at the moment. Wondering if the gas savings will eventually pay for the $1200 modification.
Almost certainly not I would say especially with your relatively low fuel prices.
For the money that you would spend to convert your card to Lindberg you could just buy a manual and call it a day. Getting between 70 and 80 miles per gallon in the manual is no easy task either. Most of the people that I have time to get about 60 miles per gallon.
I apologize for my iPhone dictation program it doesn’t really get the words right.
brehm, check your "conversations" please.
1 - 16 of 16 Posts
