P1162 code just started today, won't erase or reset.
Only have 20k miles on an NTK oem replacement. Im done messing around, Id like to find an actual OEM sensor.
Cant afford 380usd from honda parts, hoping someone has a verified good one I can buy for around 100.
Thanks
Discussion Starter #2
Once again looking for a verified good primary O2 sensor, 100 dollar budget. Thank you.
I believe there is a procedure for basic testing of the sensor in the service manuals that are stickied. It should guide you through basic tests using a voltmeter and will help isolate the problem to wiring or connectors, a problem with the sensor or a problem with the ECU. It won't help with a valve that is working but is not longer producing accurate readings.
Ive tried that sensor, and a used oem, and a 225 dollar NGK part (thankfully i was able to at least get store credit)
I will look into those procedures, thank you!
