Well I finally got to do it. You reading Jay? You were curious what my thoughts were going to be.
Let me tell you, I feel like I've had my *** handed to me. My legs are shot. I will say one thing, it's good I've been going to the gym semi regularly the past couple months because if I hadn't, there is a possibility I'd be dead.
It is a wretched, lengthy, drawn-out process.
It took me 11 hours. I started about 2:30 P.M. and I did not wrap up until about 1:30 A.M.
And I still only got two coats of Z2 on, with Z6 in between the two Z2 layers.
11 hours?! Yes. And I was not slacking. I vividly recall moments of running around, literally, actually, trying to hasten the process.
Here's what I did ... nothing out of the ordinary I don't believe, but it is what it is.
Pre-soaked the car.
Washed it with dawn.
Washed it again with the dawn sponge with just warm water.
Rinsed the car.
Dried the car with a microfiber waffle weave towel, only to realize I didn't need to after I spent all that time doing it because I had yet to clay.
Cut up a clay bar into 4 sections.
Filled a squirt bottle with Zaino car wash.
Clayed the car with the Zaino car wash as lubricant.
Let me tell you, it's amazing how much crap the clay picked up. I found a whole arsenal of stuff embedded on the rear bumper in particular. It's like stuff floated down onto it and just never moved and worked itself into the clear coat. I was never sure what to think of claying prior to actually doing it, now I'm a believer. "Just because you can't see it, don't mean it ain't there."
Washed the car with Zaino car wash to remove the film the clay leaves behind. (man, this stuff smells good.)
Again rinsed the car ...
Again dried the car ...
At this point the Insight essentially looked like it did on the lot when we picked it up.
Finally get the car into the garage about 30 minutes before dark.
Applied Z2 with a Zaino applicator. However, I've read so many horror stories about people laying it on too thick that the car needed stripped clean again so I was paranoid as hell and took it slow.
After the Z2 was dry (not too long, used ZFX in conjunction.) I buffed it out with a 100% cotton towel supposedly made in the USA.
Went over the car with the Z6 gloss enhancer spray and wiped it off. Quicker said than done, like everything else. I was trying to get everything perfect and right the first time.
Applied another round of Z2,
Hand-buffed like everything else the Z2.
Still had some Z2 left in its 2oz bottle so I Z2'd the alloys as well a coat and buffed them.
I polished ALL windows and exterior plastics, exception being the front windshield.
So ... after all that #@%!, how do I like it?
I noticed the second layer of Z2 made it look even better. After I did the 1st coat I told myself no way in hell am I getting to #3 tonight - but after seeing the result of the 2nd coat, I was genuinely curious enough to go for the third final coat in a 24 hour span (but my knees, body in general, vetoed.)
The first coat made the car shiny.
The second coat amplified it and even in lower light conditions you cannot escape the reflection of things around it. I haven't even had this thing out in the sun so far. Looking forward to seeing it in natural lighting.
I was buffing out the second coat and swore I had a streak on a couple different occasions. So, there I went, trying to buff it out but it wasn't budging. Turns out it wasn't a streak, it was the reflection of something from the ceiling. I felt "owned," or a fool, however you want to roll with it.
I did take pictures. But I haven't got them off the flash card yet.
The bad: I ran across at least two spots on the paint that have been cut due to flying debris. And there is one dent on the roof from something just above the driver side door, looked like maybe a ball bearing bounced off it. You cannot see it normally, but now that the car looks like a sheet of glass it's noticeable if you look at it from an angle.
All in all I'd have to rate the paint at 98% perhaps 99% still yet.
Additionally, there are two rock chips in the windshield. One is actually a good size, the other half of it. These need filled in with resin or something at a glass shop. Hopefully it isn't going to cost too much.
More bad: Wife locked my *** out by the time I got home. I don't know what that's all about yet. Thankfully I had a flashlight on me and went in through an alternative route.
The good: I won't have to repeat that entire process until fall sometime. I can just wash it, dry it, and go to town with additional coats if I like, which I will sometime, preferably sooner the better!
Pre-soaked the car.
Rinsed the car.
