Just wondering if the 2nd generation insights start to burn oil at higher mileage?
Had a talk with the parts manager at my Honda dealer. I just bought CVT fluid for a change. He said the only sold 9 quarts in a 18 months. I bought 6 of those. The service dept used the other 3 qts.was planning go get that done when they do the repair(s)... are most dealers reliable about having / using the correct CVT fluid ?
While this is still true, I've been receiving P0303 Cylinder 3 misfire codes for a couple weeks. Haven't noticed anything, and at the same time, an ABS code 83-01, ECM/TCM Failure, code appeared. Cleared it, and went back about my business.Will say I have not noticed any unexpected noise, smell, hesitation, smoke, or anything else to indicate this specific 2013 model is burning oil.
I do trust the oil life prediction from my years with a CR-Z. I was able to get the Insight's service history from my local dealership, and they replaced the oil+filter about a month ago.I wouldn’t even worry about the oil in there now, just wait until the MID says to change it. The oil life % is real, you can use it. In fact, you should, because the MID will not set codes for other service until it reaches 15%. But do check the oil level in between changes.
Definitely seeing where diligence in CVT fluid changes helps in a number of ways.Now if you do want to be proactive, change the CVT fluid. Use only Honda branded fluid. It is quite possible it never has been changed. The MIDwould have set the code for that around 30k. Around here we like to change it every 18-20 k or every other oil change.
