I'm fully aware of the frequently seen weak areas & common sense rebuild/upgrade recommendations for the g1 manual trans, I have a little experience with these gearboxes in the past...
I'm wondering what, if anything, more experienced folks would suggest is possible to "TEST"/check , to get ANY idea about transmission "condition overall" - before going through the work of pulling one from a wrecked non-running car. It's getting to be few-and-far between to even see G1 in the junkyards, so I will take what I can get. But my ideal goal would be to find/source a "good used transmission" backup for my beater G1 - a trans that doesn't need input shaft bearing, or 3rd gear/synchro, to be immediately addressed.
-junkyards have already drained fluid by law so can't eyeball that for fakes..
-you can run the vin & check free carfax carcare app for some mechanic history, odometer history estimates..
-yes you can check (somewhat) for input shaft play once removed, but what about before pulling from the engine/car...? (Assume: non-driving, no owner/history of the car- but crashed/wrecked, so it was running)...
....can you get a feel for synchro/gear/ ISB wear or issues, AT ALL, through the gearshift lever, by "feel"? ..or similar? Can anything (like ISB wear) be felt/noticed by observing the front wheels in gear up on blocks/etc? any related tips, tricks, or thoughts? Thanks!!
