Background - "00 w/ 180K miles MT.
Symptoms - As soon as the car tries to get to lean burn it it triggers the p1165 code. This has been the case for a few thousand miles now. If I don't clear it with a few hundred miles it'll trigger the CEL light on the dash. Of course there's jerky driving once the code appears. I drive now with an OBDII reader plugged in so clear it often.
What I've tried -
the EGR plate is very clean, I replaced the EGR valve once and recently shot cleaner inside this newer one just in case. I've also replaced the upper A/F sensor wtih a new NGK one that happened prior to the code being an issue. I've also removed the converter tried looking through it, it didn't looked clogged, and rinse it out with acetone hoping to remove any possible build-up none seen. Lastly I've taken both the A/F sensor and the only O2 sensor off the car to heat them up on the stove flame hoping there might be some carbon that I could maybe burn off that did nothing to resolve my issue. The ground straps look fine, definitely the three uppers are fine not sure about the lowest one near the tranny
Has anyone had any luck resolving their code like this? Was it their catalytic converter? Was it their O2 sensor? Can the CC be rebuilt?
What I've tried -
