C1555 code
29K views 9 replies 6 participants last post by  shawncav
#1 ·
This morning after starting the car, I got a Check IMA system on the dash. first time ever.
Scangauge is always on, so I checked it and it said C1555, I tried to reset it, but no response. Any ideas?
#3 ·
#5 ·
Thanks guys. I'm trying to avoid having to take it to the dealer, I have almost 150k on it...
but I do need a new battery, dealer usually has a sale on them. Maybe Ill just disconnect the battery tonight for 15 minutes and see if the code clears and does or deosnt come back.
I googles the code, and found the same stuff. Only thing the dash said was CHECK IMA system.
Thanks
#6 ·
Do the blink codes, no fancy gauge, no dealership, just need a small paper clip as a jumper.
Scott
#7 ·
Just to be sure, you did not blow the auxiliary fuse? I did and it caused a Check IMA warning.
Remote door locks and interior lights still work? Cause those were gone too when my $0.50 fuse blew.
