Two days ago the check engine light came on. p1575, motor power inverter module voltage malfunction (per Autozone). Assist and regen appear normal.
Two weeks ago at morning startup heard a loud noise like a broken fan belt hitting sheet metal and engine failed to start. IMA light and check engine light illuminated. I switched the key off and (after my heart rate returned to near normal) made a second attempt to start engine. Engine started normally with the IMA, IMA light went out and check engine light stayed on. After running a few errands (3-4 miles) I pulled the 12v neg. cable, reset the check engine light and no more problems until two days ago.
Allso, about four weeks ago also at morning startup I turned the key, IMA briefly engaged engine did not start. IMA light lit. I turned key again and engine started on the 12v system. I immediately pulled the 12v neg cable and had no more issues for two weeks.
A search turned up a similar incident in 2010 but I could not find any follow up to his problem. Is anyone familiar with this malfunction and can you see what the future holds for this machine.
Thanks for your input.
