41 - 60 of 88 Posts
Unverified info gathered from the RockAuto catalog. Different brands had different application info in some cases.
Blower motor without wheel:
ACURA CL 1997-1999
ACURA EL 1997-2000
ACURA INTEGRA 1994-2001
CHRYSLER ASPEN 2007-2008
DODGE DURANGO 2001-2008
GEO PRIZM 1989-1992
HONDA ACCORD 1994-1997
HONDA CIVIC 1992-2000
HONDA CIVIC DEL SOL 1993-1997
HONDA CR-V 1997-2001
HONDA INSIGHT 2001-2006
HONDA ODYSSEY 1995-2004
HONDA PRELUDE 1992-1996
ISUZU OASIS 1996-1999
TOYOTA COROLLA 1988-1992
Blower motor with wheel:
ACURA CL 1997-1999
HONDA CIVIC 1994-2000
HONDA INSIGHT 2000-2006
Blower resistor:
HONDA CIVIC 1999-2000
Headlamp switch:
HONDA S2000 2001-2009
Power window switch (right):
Back up lamp switch:
ACURA RSX 2002-2006
ACURA TL 2004-2008
HONDA ACCORD 2008-2012
HONDA CIVIC 2001-2012
HONDA CR-V 2002
HONDA CR-Z 2011-2012
HONDA ELEMENT 2003-2009
Door lock actuator (left):
ACURA CL 2001-2003
ACURA MDX 2001-2006
ACURA TL 1999-2003
HONDA ACCORD 1998-2002
HONDA CIVIC 2001-2005
HONDA CR-V 2002-2006
HONDA FIT 2007-2008
HONDA ODYSSEY 1999-2004
HONDA S2000 2000-2009
Door lock actuator (right):
HONDA FIT 2007-2008
What: Antenna Whip
For: 2000-2006 Honda Insight
Donor Car: 2006-2011 Hyundai Accent & Kia Rio
Modification required: None, but you could consider trimming the rubber that extends passed the stud.
Why: Shorter and nicer than the OEM longer whip
How: Just screw it on. Takes a bit of pressure due to the extended rubber that gets stretched out.
I had problems with an Accord EGR valve because the opening was too small. I got P1941 for it. I wanted to post here that someone else suggested a different EGR valve:
Dorman 911-756
It's meant for the Honda Odyssey, but is exactly the same and has the larger rectangular passage that the Insight EGR has. The Dorman valve worked for me -- no more CEL.
It just unscrews from the base. You might need to get some pliers on it, but mine simply unscrewed.
Thanks, mine is literally falling apart, it's a spring with a metal rod. All of the plastic has crumbled off, looks like I need to grab some pliers and replace it soon. Also gotta find the rubber grommet that goes around the bottom, thats been baked in the sun for far too long.
I like the shorter assembly, I have already replaced the mast on my wife's car with a factory mast from Sterling McCall (G1parts) for 24 bucks or I'd do this.
Before you do anything rash... Before I bought a replacement, I took some black heat shrink tube, y’know, for wires, and put several layers on the doggone thing. It wasn’t perfect, but it looked ok for 5 feet away. You can do it in place, too. No need to remove it.
Please include your location in your Profile.
Thank you.
Insight Parts Interchange List & Junkyard Mods
As sale of new parts are discontinued, cars are scrapped, and used parts become rarer every day, I thought it important to resurrect this topic.
The purpose of this thread is to document alternate parts interchangeability so that we can find parts that we would not have thought of otherwise. (For example the Accord door handles)
We have discussed it previously (there is a 10 year old thread, but that title was "Honda parts only"; and the last time I posted this list it was hard to find under the Accord Door Handle title). Again, credit to Mathemaddicts.
If you know of another part, add to the list.
- 94 era Accord chrome door handles (hint: rear door handles on 4 door cars are usually barely used. These may also be available as reproduction on Amazon for cheap.)
- Daewoo Matiz/Chevy Aveo Springs
- Chevy V6 EGR Valve
- CRV/Civic Si/S2000 Orange display CD Player
- Acura RSX/S2000 Leather Steering wheel
- U1, U1L, U1-7 Tractor Batteries
- '98-'02 Honda Accord 4 Cyl EGR Valve (Thanks Jeff) OEM Part #: 18710-PAA-A01 Standard Motor Products #: EGV980; Parts Geek #: 5981-01174093
- Corolla/VW 9" or 16" whip antennas (All over eBay $5 shipped in US for new ones.)
- Acura 2 button remote (clicker) case
- Daewoo Matiz rear bump rubbers
- S2000 stock speakers. More power, and plastic cones. Same shallow dimension. (Thanks Chris!)
- [this is not a Junkyard Mod, but an important enough aftermarket wear item for consideration] NTK LAF sensor, part #24301, Amazon, $115.79 vs. $306.10 Majestic, two testers. jime
- 96 Civic Window Vent Shade (external vent visor for side door? (Thank you KevinD)
- "Company AVS makes a vent shade that is almost perfect fit for the 2006 insight. Part #94623 made for Dodge 02-08 Ram 1500. " (Thanks Dale La Roy Smith)
- Gen2 floor mats ---> will work unless you suffer from OCD. Gen2 have cut outs in places where Gen1 mats are straight. Gen 2 has Insight script on both L/R. I am using Gen2 All-Weather mats for the winter.
- "Security Control Unit" from an S2000 will work in our cars. (Thanks Musmanjam)
- A/C Evaporator Core (Front) from Acura Integra 1998 - 2001, Honda Civic 1998 - 2000, Honda CRV 1997 - 2001
- 2001 - 2003 Acura CL Clock Spring (Thanks Natalya)
Known Seat Swaps (with some bracket mods):
-Nissan 350Z;
-Mitsu Lancer EVO;
-Honda CRZ;
-Honda S2000
-Acura RSX;
Pending verification:
- 2000 Civic/CRX rubber pedal cover ?;
- Accord 02 Sensor? Bosch 13075 part number is listed for the same. Honda has different numbers. ???? If you care to do further research or trial, here is a link: [ame]Bosch 13075 Oxygen Sensor, OE Fitment (Honda):Amazon:Automotive
- Acura RSX or Civic Steering Column for Tilt Wheel Mod ?
The universal clutch and brake pedal rubbers sold at autozone for cheap with a slight trim on backside will fit quit nicely on our gen one pedals and i use a dab of epoxy underneath on the bare alcohol wiped pedal then put some rubberbands on for a couple of hours and when hardened they look as good as they wouldve in 2000 all for $10 pair. Rich
May I suggest you add a parts number for Autozone.
Still got my originals after 450K miles.
41 - 60 of 88 Posts
